wd45
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: wd45
    Posted: 28 Aug 2010 at 7:38pm
The hand clutch on my 45 is slipping,is there any adjustments to stop it.  the pto does not stop or slow down when the clutch is slipping.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:05pm
  chek to see how many shims are in the clutch  can remove some  cover under battery
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:09pm
Take your Battery off and removed the Oval Cover below it. You'll see the hand clutch in thier with the clutch released you should have .030" Gap. If more remove the shims between the pressure plate and back untill you reach .030" and put back together. thier will be 3 sets of two bolts each. put the shims you remove behind the presure plate. If you drop parts you'll ned to drain the PTO housing and remove it to get them back, so don't drop the parts. I have been succesful using a magnet some times.
Edited by Dakota Dave - 28 Aug 2010 at 8:10pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 9:04pm
The facings on the 3 disc's may be worn-out, Most advise is to re-shim the unit, but what if the clutch disc's themselves are shot??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:03pm
Jim,
Good luck and not dropping anything in there.
While you guys are on clutches, my 1950 WD makes a ticking or rythmic sound form the clutch area. As far as I know, my hand clutch does not slip, and my foot clutch does not slip. But today I was trying to plow and I could hear a noise in the clutch area, both while I am going and while the tractor is idling in neutral. Any ideas guys?
Thanks
Pastor Mike in Iowa
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 10:44pm
remove the square plate from the bottom of the bell.check the throw out arms for wear also ck the throwout bearing for excessive wear of the bearing race with a long thin blade screwdriver excessive wear on the inner bearing will show up doing this.next crank her up and listen at the open plate if it is the foot clutch you will definitly hear it.i had the same problem on my 45-D.ended up replacing the pressure plate and throwuot bearing.does the hand clutch have a positive snap when engaged and disengaged ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 9:23pm
J. W.
Thanks for the ideas. I will do it when I get a chance. Yes the hand clutch has a good snap to it yet.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:05pm
I bought a new to me WD 45 had a light clunking sound coming from the transmition. It would stop when I pushed the hand clutch in. When I took it apart I found 2 nuts shaved down to 1/2 thickness in the bottom of the Hand clutch housing. and one lock plate. I drained and removed the PTO housing. I got enough ground up steel to be the third missing nut. I cleand out and replaced the nuts and lock plates . Its now smoth as can be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:42pm
dave..where were these nuts located i cannot picture it as of now.good info...
This page was generated in 0.961 seconds.
