WD45 with cycle bar mower??
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Topic: WD45 with cycle bar mower??
    Posted: 24 Jan 2010 at 6:48pm
   Just bought a 56 WD45 with a mid-mounted cycle bar mower on it. Never saw one like this before. It's a factory AC mower(still has decals on it) It says Twin screws  or something like that on the main housing that sit in front of the right wheel. It hangs off a big 3 or 4 in tube that is bolted to the right side frame rail. The main housing of it  sits in two J-hook type saddles below the frame rail. There's a belt pulley attached to the main housing with a PTO shaft that goes from the housing to the rear of the tractor and it is attached to a pulley coming off the tractor PTO.  Can any one tell me what model this is and where I can find info for maint. on it Pictures if some one has some. Sorry for the long post.
       FredinInd     Good to be back, had trouble logging in, had to reregistar again.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 6:50pm
sounds like it is a 80s or an 82s the s stands for side mount
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 6:55pm
any pics?
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:03pm
Sounds like this calls for a photo.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:06pm
If it lifts with a hydraulic cylinder it is a 82S.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:44pm
Thanks Eldon, it does lift with a hydralic cylinder. Forgot to mention that. Won't have pics for 2 or 3 weeks. Was hoping some one here had some pics so I could identify model #. Went to pick up some parts I purchased from  this fellow today and he had just brought it home. It just wouldn't fit in my chevy S10. Thanks for the info guys,
         FredinInd
