WD45 wide front
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Topic: WD45 wide front
    Posted: 30 Jan 2021 at 2:39pm
I have a 1954 wd45 with a fully rebuilt wide front end. New bushings, tie rods, and seals. It is 12v positive ground with a generator. Brand new battery, battery box, voltage regulator, tail light, and wiring including a key switch. The distributor has new points and condenser in it and new plugs and wires. The radiator has new hoses and fresh antifreeze in it. I put a brand new snap ring in the wet clutch so it works properly. There is no fluid in the rear wheels that I am aware of so there will be no rusting. The front wheels are 6 lug from a wc for something different. It comes with a factory snap couple blade in excellent condition, every adjustment works on it and there are no breaks or welds. The only thing it really needs is the hydraulic cylinders to be rebuilt. Starts right up and runs great. Would make a great piece to restore as its complete and functioning. I am open to trades, I collect mostly unstyled tractors. I am located near walcott iowa. I can not post pictures here so please message me.
