WD-45 Wide Front
WDmatt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDmatt Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Wide Front
    Posted: 12 Jun 2020 at 10:16am
What is the difference between the 3 and 4 bold wide fronts? I found a 4 bolt wide front listed on Facebook, advertised for a WD-45. I'm wondering if it will fit.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 2:54pm
3 bolt fronts were weaker inthe attachment and some broke out and used on the WD tractors... the 4 bolt front block were tougher and used on WD45 tractors... and will slip right in on the frame rails.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:36pm
It must have the bloster to work. Ours always wore out in the hole first, tubing for axle extensions second— have had both 3 and 4 bolts on for extended service( moves 1000# bales daily), not really sure the 4 bolt was any better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 7:16am
Never seen a 4-bolt bracket work loose causing any damage. Have seen dozens of 3-bolt brackets work loose and damage things beyond a good repair short of welding up a new homemade bracket. If you were using a 3-bolt heavily loaded and never had trouble, you were LUCKY.
