Wd45 wide front disassembly
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 wide front disassembly
    Posted: 17 Feb 2018 at 2:12pm
I have a 4 bolt wide front for my wd45. I want to replace the output seal. I am having trouble getting the gear off of the output shaft. It appears to be keyed with a press fit. I tried a gear puller but it doesn't budge. Any suggestions?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 7:17am
When I did mine about 8 years ago, I had to put it in a press and push the shaft out of the gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 12:26pm
The problem with pressing is I don't know how to get past the stop welded to the gear. I'm thinking about packing the gearbox full of grease instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 1:04pm
I don't remember about the stop. I just remember pulling it all part, not being able to get the gear off, then pressing the shaft out. I had everything completely out of the gearbox
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 7:43pm
The grease certainly not leak out as fast, but it will take a bunch of it. Probably be best to use that old ropey stuff we used to use in the old days. After all you're not going into a corner at 200 MPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 8:19pm
My CA was a bit sloppy and had grease in it. I took it all apart, replaced seals and bearings and put gear lube back in. It all leaked out the bottom in a years time, so I filled it with grease. Cornhead grease would be a good choice IMO.
