WD-45 wheel weights
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 wheel weights
    Posted: 18 Nov 2016 at 6:09pm
Just removed fluid from my 45 and had new tubes installed. Tired of fighting bad valve stems. Wondering what factory 45 wheel weights weigh each.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 6:23pm
135 pounds each. Not anywhere near what the fluid provides. I have both the fluid and wheel weights on my '45
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 12:42am
if you put 4 ac wheel weights on each side it may not be as much as the fluid' but you have the right point' the weights won't rot the rims out anymore sr..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 5:56am
Four weights on each rear wheel should bring it back to where full fluid would have been. A new tube should last 15 or 20 years I would think. Using RV antifreeze and one wheel weight would get you back to original full fluid as the RV juice is lighter per gallon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 5:00pm
Well, you get a lot more from the fluid than just the weights. If you take care of them properly, the tire, tubes and wheels will last a long time. On my '45, which my Grandpa first bought new, I'm still on the original wheels with fluid in them. When/if they start to leak (usually around the valve stem) fix it and you'll be ok. Dave
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 6:57pm
Thanks for the good suggestions and information.
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 10:10am
Mine weighed 141 on the scale
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 11:10am
I used my wife's scale!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:59am
The weights for the late B look just like the weights for the WD, except they are one inch larger, and have little notches in the corners of the half moon cutouts on the outside edge.  These are slightly heavier, and would weigh about 140-150.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:33am
Replace the valve cores every other year with CaCl and you won't have problems either...just another maintenance item like changing oil.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:38am
Yeah, I've had to replace valve cores on some of mine when I notice a leak. Not a big deal to do.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:36am
I have 3 weights stacked out on each side of my WD45. It's just barely enough weight. If I throw a dual on the land side for plowing it makes a HUGE difference and I have to weight issues. I think the heavy tire helps more the traction of the tire. 3 weights stack out pretty far. 4 would stick out really far. I can barely get the duals on with 3 weights. I don't think I could with 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 10:57am
What about that Rim Guard fluid?
Since I'm putting new tires on my CA I thought I might have that put in it.
Edited by Brian Jasper co. Ia - 22 Nov 2016 at 10:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 1:35pm
I actually just checked about rimguard a couple weeks ago. From the local dealers here it's $3 a gallon or they sell good old calcium for $1 a gallon
This page was generated in 0.242 seconds.
