WD45 very nice original at auction |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Feb 2012 at 3:06pm |
There are a couple pics at the auction site. Probably not running but appears to have pristine original tin. I'll probably be watching it!
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3927 |
Looks like a flood went through there the way that one is sunk into the ground!!
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
For some reason or another the radiator tin, looks like someone cut a huge hole around the fill neck
Still in use:
Rfdeere ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
It was "pristine original tin" until someone torched a hole in the front of the hood and grill shroud.
http://www.rumelyallis.com |
Isn't one hole for the rad cap and the other for the temp gage?
wdforty5 ![]() Silver Level ![]() Joined: 08 Sep 2011 Location: Illinois Points: 163 |
Yes, but the hole in the grill shroud should be just big enough for the fill neck, and does not extend into the hood:
Maybe the hood hasn't been cut, looking closer.
Looks like the radiator has been changed, or some work has been done on it, the fill neck should extend above the shroud, that must be why the hole was enlarged, to get the cap off.
Still in use:
AllisChalmers37 ![]() Orange Level ![]() ![]() Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
Was I the only one who thought they were on the wrong website when the first pictures came up??
Yes you were!!! :-)
Still in use:
