WD45 - Very High Oil Pressure |
Post Reply |
StanGreen
Bronze Level Joined: 13 Nov 2022 Location: US Points: 43 |
Posted: 8 hours 34 minutes ago at 8:52pm |
On my WD45 today, I notices the oil pressure gauge is pegged to the high side at idle. I had the motor rebuilt last year. The oil does not look like it is over filled. Is it OK to have this high of oil pressure? If not, what would be my first step to address this issue?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80590 |
get a good gauge and read the REAL pressure..
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 923 |
I have the same issue with one of my 201 engines. I put a real gauge on there and it reads 90 lbs. I had to believe it reading a real gauge. Once the engine warms up the original gauge points straight up in the normal range (still about 45 lbs on the real gauge). I have now changed oil putting much thinner oil in it. The gauge still goes over to the far end on cold start up but takes shorter time to come back to the middle. A mystery to me.
jvin248
Silver Level Joined: 17 Jan 2022 Location: Detroit Points: 304 |
. Gauges fail. Verify and if bad then replace it. .
does the "Rebuilt" motor use the old BYPASS jar lip thread filter.... or the PH8 type automotive full flow filter ??
Orange Level Access Joined: 12 Sep 2009 Points: 20323 |
Remove the filter base tube and clean it out by ramming a piece of wire down thru it and blowing air into it.
Post Reply | |
