Wd45 valve cover torque specs |
Allis-chalmers wd45 ![]() Orange Level ![]() Joined: 11 Apr 2012 Location: Newton, Nj Points: 1917 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2012 at 9:06pm |
Hey guys what are the torque Specs for the valve cover nuts ? I think there way over tightened thanks -justin
Edited by Allis-chalmers wd45 - 25 Apr 2012 at 10:01pm |
Would his contribute to it smoking?
Rog(NCWI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Aniwa.WI Points: 243 |
I doubt it. Just snug them up. Use sealer on the gasket to stop any leakage. If it leaks, tighten up a bit.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If it has been over-tightened, it probably needs hammered out. They bend quite easily and get distorted so the gasket doesn't seal properly. Take it off and use a straight edge to see how bent up it is. A nut drive will get the bolts tight enough without using a ratchet.
Yes, if oil is leaking out from the gasket and running down on the manifold. It has nothing to do with burned oil coming out of the exhaust. |
