wd45 trans leak
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Topic: wd45 trans leak
    Posted: 08 Sep 2010 at 7:09am
my trans is leaking and it seems to drip out from right behind where the hand clutch lever linkage hooks to the side of the clutch housing on the right side..is there a seal behind there? and is it easy to change?
Edited by Jeff(WC)(MI) - 08 Sep 2010 at 7:10am
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 7:13am
Jeff, you gonna have the tractor ready for the Mac Bridge drive on the 17th?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 7:25am
yep..that little leak won't stop me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:00am
Yup, that's one thing I've learned about you...
Hey, maybe I can get my act together and get my neighbor's WD NF together good enough to make the bridge too. We'll see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:09am
let me know if you do..i'll see ya up there
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:12am
Yup, will do - gonna check into it right now.
Another good reason to get married again - ifn I had a wife, she'd a been bitchin at me since June about it - and I wouldn't have forgotten.
(sigh)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:43pm
no one knows whats behind there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:46pm
In your case - oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:48pm
there wasn;t when i bought the tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:53pm
Well, 'm not being a smart arse now...
Are you talking about the pin about 3" or so long that the hand clutch lever itself pivots on?
I just pulled that lever off this weekend to get brakes going on the WD, and it's NOT rigid - meaning I can see where after years of use, that pin would wear enough to let oil ooze by - if the tranny was that full.
So, is the tranny THAT full?
Edited by CJohnS MI - 08 Sep 2010 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:58pm
it's not where the lever pivots...it's where the linkiage attached to the lever, enters the clutch housing....forward from the lever about 8-10 inches
tranny/differential took 16 quarts...it holds 17 total..so it was LOW...now it's filled to bottom of threads on both fill plugs on left hand side
Edited by Jeff(WC)(MI) - 08 Sep 2010 at 8:59pm
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 9:24pm
There is a seal there, the AC part number is 224644.  You'll need to take the cover off the hand clutch housing so you can take out the taper set screw from the shifter fork so you can pull that shaft out.  Then you need to hold things in place from the top to put the shaft back in again.  If the leak is real slow maybe it would be better to just check it regularly and add as needed.
Bill in Md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 6:32am
do you need to pull the frame rail off to change that seal? i have the same leak.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:56am
Yea, ya gotta pull the frame rail off to get the shaft out.  Also check the bolts that hold the trans housing to the torque tube, the are two on each side that come in from the back, and one on each side that comes in from the front.  If these are loose it will leak oil about where Jeffs is leaking.    HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill in Md Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 10:27am
ok, thanks, i know mine is the seal. gotta replace the rear main in the engine now also. will do it all at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 11:25am
thanks guys i will check those bolts and check it over a little further...shoulda done it when the motor was just out....hind sight is so clear!
This page was generated in 0.191 seconds.
