Wd45 Traction booster
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 Traction booster
    Posted: 12 Apr 2012 at 7:50am
I don't have the traction booster gauge so I was wondering if the traction booster will still work? Also is there a knob to turn on traction booster or lock it out?
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:08am
  the guage is just t'd into the system, so it will work without a guage.  The system is adjusted with linkage to the hydraulic pump, the best thing to do would be to get an owners manual to learn how to use/adjust it.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:56am
The decal on the battery box, if you have one, explains everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 1:35pm
Alright thank you! I guess I'll have to get one because I can't get it to work?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:02pm
Here you go.
Don
