WD45 Timing cover alignment tool
MrSuter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSuter Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Timing cover alignment tool
    Posted: 16 Nov 2024 at 4:23pm
I am working on putting together my WD45 engine. I appreciate the video showing how to seal it up so that it doesn't leak. I'm unsure how to make the tool to align the timing cover though. Any advice would be appreciated. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2024 at 10:23pm
My tool is 70 years old and is like a speedi-sleeve for a worn shaft only it slips on and off the crankshaft nose. Tighten the bolts while the sleeve centers the cover on the crank and remove when done. You could make one out of pipe to use the seal OD bore as the pilot on the cranks nose.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 11:31am
This is what I made to install a cover on a 170 engine
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 6:13am
I made one out of brass on a lathe, think I even homed the ID to get a nice fit. Cut a 30 degree taper to engage the cover. Wasn't happy with the way things looked so, set up a dial indicator and located them that way.
This page was generated in 0.095 seconds.
