WD45 stuck in reverse
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Topic: WD45 stuck in reverse
    Posted: 5 hours 12 minutes ago at 5:04pm
I can't say it any better, feels like the shifter does nothing,tractor runs fine but can't select a forward gear. It will back up so it seems like only one gear is engaged, how bad is this to fix?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 21 minutes ago at 5:55pm
It may not be a big deal. I would pull the tower and look at the wear on the ball on of the shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 43 minutes ago at 6:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 12 minutes ago at 8:04pm
That's a great video. For a novice repairman, he caught on pretty quickly as to what the problem was.
