WD45 steering
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: WD45 steering
    Posted: 27 Jan 2011 at 5:21pm
Was wondering if it's much of a job to take the shimmy out of the front end of a 45. Thanks.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 11:32pm
What I remember from years ago when dad was the mechanic in the area,the shaft from the gear to the spindle used to get the keyways wollowed.I don't remember him replacing spindle casting or gears but there are still several old worn shafts up at the shop.Bearing end play on the worm shaft is the only adjustment provided.(shims) No provision to move worm closer to gear. Big bolt in bottom of shaft holds spindle on.
Edited by Steve M C/IL - 27 Jan 2011 at 11:33pm
fordf350dually View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 11:53am
on my wd there is a bolt with a lock nut on it you can tighten. made a world of difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 2:05pm
that bolt/locknut on the gear inside housing?
This page was generated in 0.180 seconds.
