WD45 Steering System |
Post Reply |
NEB-KC
Bronze Level Joined: 21 Nov 2013 Location: Paola, KS Points: 27 |
Posted: 04 Mar 2020 at 10:56am |
I have lost oil from the worm gear compartment, but I can’t figure our how to access the compartment. The WD manual says to remove the cover from the top of the front support. There is a round cap on the top, a couple of inches in diameter, but I don’t know how to remove it. Help?
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
Remove the drain plug and put a grease zerk in it's place. Pump a couple tubes of corn head grease in it and call it good. JMO
NEB-KC
Thanks for your suggestion. The drain plug is 1/4” pipe thread. I haven’t yet been able to find a zertz fitting that sized. Their is a lot of discussion and disagreement about using corn head grease in sterling units, all of which I haven’t reconcilled.
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
I was in the same boat as far as using it, but when Old Guard recommends it - I used it and no problems on my 1955 WD45.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Do not use regular grease. It will eventually get hard and not be in the places it needs to be. Mine got so hard to steer it was almost impossible to turn. I took the cover off, cleaned out all the old hard grease and filled it with corn head grease. It steers great now.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3651 |
Just get a 1/4 in to 1/8 in pipe reducer bushing and screw in a regular 1/8 in grease zerk.
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
That round plug you're talking about can be popped out using a medium sized chisel. set it under the lip and carefully tap it working around as much as you can. If it hasn't come out, get a bigger chisel. When you get ready to put it back in clean and brush it, put on a small bead of RTV and tap into place. Leon
CTuckerNWIL
There is no need for a 1/4npt fitting when you can buy a reducer bushing. Yo can also buy the 1/4 npt fitting if you look for one. https://www.discounthydraulichose.com/36-130.html?gclid=Cj0KCQiAqY3zBRDQARIsAJeCVxOEMz4TE4wddM-qCC7Dv8qlo9YVJ89ap_LG0wHkHJ1XbeWtRwIMlpcaAqY0EALw_wcB Cornhead grease works great in just about any gearbox. I've had a combination of regular grease and a bit of gear lube in the gearbox on a 5 foot Ford rotary cutter for close to 30 years. It doesn't leak out like gear lube will and keeps things running smooth. |
Post Reply | |
