WD45 Steering box
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Steering box
    Posted: 29 Jul 2023 at 8:55pm
It has been asked before, but what is the correct grade and quantity of oil to use in the steering box of a WD45?  The manual is quite vague.
I know many people use corn head grease.  I have replaced every seal in the unit, so I am quite confident that the oil should not leak out.
This is the one for my 1957 gasser.  I have another one coming up very soon on my diesel.  It has a plug where the crank rod goes through on the gas model - it appears to be leaking from there.  Is the oil level typically that high on the diesel?
Many thanks!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 6:02am
When I did the front end 'upgrade' on my 45, pretty sure I put 90 weight in it. Now I'm not sure that it is correct but pretty sure it's better than nothing. On the downside, I had not replaced the seals and it has been leaking out ever since. If I live long enough it will get gone through. Otherwise, corn head grease!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 6:44am
The hand crank shaft isn't sealed on any of those front ends are they ??? So, any oil you use will seep when the tractor is severely nose up or down. Put in it whatever you want, but lighter viscosity will seep more than heavier.     From a WD-45 owners manual:  Maintain oil level so the worm gear is 1/3 submerged on the level. Use SAE 140 oil unless it is a wide front end and then use SAE 250 weight oil.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 7:23am
I'm thinking corn head grease is rated as 200 wt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 10:28am
Used 75-90 synthetic leaks easily....
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 11:28am
00 Grease in my WC, never had a problem
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
