wd45 starter |
TomYaz
Topic: wd45 starterPosted: 25 Jun 2012 at 6:02pm |
Starter spins but doesnt engage the ring.
Pulled starter, ring looks fine. When I engage the starter, the gear on it spins, but it is supposed to move forward as well to engage the ring, correct? Well it isnt...
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 25 Jun 2012 at 9:52pm |
That is how it suppose to work!
Can you turn the gear by hand? and resistance?
The force of the rotation should spin it in to engage.
Bob
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 25 Jun 2012 at 10:04pm |
Sometimes there is a burr that the gear hangs up on. You may need to use a Dremel grinder to remove the burr.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6500 |
Posted: 25 Jun 2012 at 10:55pm |
Sometimes the bendix needs cleaning and a light application of dry film lube. It is probably a burr as mentioned or some grease and dirt holding the gear back.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8676 |
Posted: 26 Jun 2012 at 12:17am |
Because it is an "inertia" bendix,it must be free to spiral down the shaft.
TomYaz
Posted: 26 Jun 2012 at 3:43am |
Didnt try to spin it manually, it does spin when powered up...but doesnt travel down the shaft. Thanks guys, will check for a burr or the like.
CTuckerNWIL
Posted: 26 Jun 2012 at 6:37am |
Use some kind of cleaning agent (brake clean, carb clean) to clean the crud and sprinkle some graphite on it. Don't oil or grease the shaft.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 26 Jun 2012 at 8:30am |
Never oil a bendix drive! Do as Tuck said. Clean the drive with Brakekleen and dust it with graphite spray. Good to go. If oil starts slinging into the starter motor, you're gonna have a mucky gooy mess inside the motor that you don't want.
