wd45 starter compatibility
JoshuaJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshuaJames Quote  Post ReplyReply Direct Link To This Post Topic: wd45 starter compatibility
    Posted: 11 Nov 2023 at 11:37am
Does anyone know if a d15 starter will fit and work in a wd45? They look to be similar in design.
Edited by JoshuaJames - 11 Nov 2023 at 4:09pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 7:03am
Pretty sure it will not. Hopefully someone who knows for sure will chime in.
Welcome to the forum!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 7:41am
The WD/WD45 Delco 1107951 and the 1107758 D14/15 gas Starters are two different animals. The chassis' may look similar, but the operating components are different from one another. If you have a WD/WD45 stick with the 951 if staying with 6 volt. If your intention is to switch to 12V, I can convert the 6V unit to 12V if interested. When switching to 12V I offer the optional starter solenoid and eliminate the poor design mechanical switch. You then can go to a key crank start system as a nice upgrade. Your choice. If interested, shoot me an email. Be happy to help you out in anyway...Thumbs Up
Steve@B&B
bb-customcircuits.com
