WD-45 Smoking? |
| Author | ||
Foreign.Perspective
Topic: WD-45 Smoking?Posted: 02 Oct 2018 at 9:40pm |
I have a question for someone with more wisdom than I. Have a WD-45 has tractor that I bought, planning to rebuild. Got it running & started using it, just to determine the condition of everything.
After 12 hours of operation it started smoking badly- even to the point of soaking the exhaust pipe with oil. I had beef idling it a lot, moving hay. I put it in the barn for a winter overhaul. When planting winter pastures my main tractor broke down & I pulled the WD-45 out to finish planting. As soon as I put it under a heavy load, it cleared up and completely stopped smoking- running great. As soon as I idle it down a few minutes it starts smoking badly again. This had me baffled. Any ideas what is causing this? I still plan to overhaul the engine, but would still like to know what’s going on. Any input from you more experienced folks would be appreciated. |
| Sponsored Links | ||
Posted: 03 Oct 2018 at 7:22am |
If you are planning a complete OH, your problem is solved. New pistons/sleeves/rings/ main & rod bearings/ reground crankshaft/new cam bearings/valves and valve guides will dry it up like it was when new.
Gerald J.
Posted: 03 Oct 2018 at 10:12am |
What color is the smoke? Black smoke comes from fuel too rich (like being choked). Could be the idle jet is getting too much fuel. Blue comes from burning crankcase oil. Gray comes from steam of coolant leaking into cylinders.
Gerald J. |
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 03 Oct 2018 at 3:54pm |
You might have an oil ring that is sticking. You might running it under a good load like plowing along with adding some Sea Foam or ATF to the engine oil to aid in cleaning. You have nothing to lose at this point because if it fails to improve then a rebuild is next.
1957 WD45 dad's first AC
Foreign.Perspective
Posted: 03 Oct 2018 at 7:23pm |
Thanks guys!
While I’m planning a rebuild anyway, I am trying to figure what the main cause. It is blue crankcase oil. Wondering if it could be valve guides? Possibly worse because of the increased vacuum at idle? I was thinking that a stuck oil ring would still smoke under heavy load at higher RPM. I DONT know though- that’s why I value y’alls opinion. Thanks! |
Big Orange
Posted: 04 Oct 2018 at 3:06pm |
The engine needs a rebuild! Ok this is going to upset a lot of people on here, but after the rebuild use a good grade of non-detergent oil in it ! As that engine was made way before detergent oil was ever herd of, it has no full flow oil filter, to filter out the dirt in the oil before it goes to the bearings. I know the new oils are all high detergent and are good oils for newer engines, but not for this type engine. I worked as mechanic in the 1960's, at that time the oil company's were make high detergent oils & selling it all the farmers in my area. Farmers were having there old tractor rebuilt & using the new oil, but engines didn't last 10 years as they had before, only 1 or 2 years. The only difference was the oil, so the problem had to be the oil. I rebuilt the engines, they went back the old oil & no more problems. If a engine has a full flow oil filter system it will last longer than 10 years on the high detergent oils.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3073 |
Posted: 05 Oct 2018 at 6:29am |
So if you use non-detergent oil, where's the dirt go? It stay's gunked up in the engine. That doesn't sound much better.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
Posted: 05 Oct 2018 at 7:46am |
Wow Big O, that is totally a new one on me. |
Gerald J.
Posted: 05 Oct 2018 at 9:52am |
Besides the detergent modern oils contain other additives that seriously extend engine life. One prevents moisture in the oil from making a battery of the silver or copper lined crankshaft bearing inserts against the steel crankshaft that without the additive eats the silver or copper rapidly. Before detergent oil with these other additives auto engines needed rebuilding every 30,000 miles. With modern multigrade detergent oils auto engines run over 150,000 miles without rebuilding. I remember an article in Lubrication magazine way back then where they compared New York city cab engines that needed rebuilding often with the non detergent oil of that era to cab engines with the new detergent oil. The engines with the new oil ran several times the miles of the engines of the same construction running the old oil.
In my opinion running non detergent oil is abusing the engine. Gerald J. |
DougS
Posted: 05 Oct 2018 at 10:41am |
It's more than just dirt. It's sludge. Engines made in the 30s, 40s and 50s were actually easier on oil than today's engines. Today's engines have higher compression, run hotter and turn faster than the old engines. With or without oil filters, you'd destroy a newer engine in a heartbeat if you used non-detergent oil. Clog even one oil passage and see how long the engine will last. Those old engines used non-detergent oil because there wasn't a good detergent oil available. |
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 710 |
Posted: 05 Oct 2018 at 10:43am |
Once the engine is cleaned out from an overhaul, run detergent oil and change the oil. It keeps the dirt suspended and is drained out with the oil change. Full flow or not, getting the dirt out and keeping deposits from forming are a good thing. I like HDEO (Rotella) in old stuff for the zinc, but any quality oil will work.
The only time I would ever suggest considering non-detergent oil at this point is if you are not overhauling and you have a tractor where the engine has used it for decades are you are afraid of knocking the crud loose. Even then, I have not followed this advice on my B. I got it with 2 stuck pistons, freed it up and never have had the pan off of it. After getting everything working I did about 3 oil changes in close succession and now it is running on Rotell conventional 15w40. So far, so good.
1951 B
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 05 Oct 2018 at 6:39pm |
Might be just worn valve guides.May have done lower end and negelected head.
Big Orange
Posted: 06 Oct 2018 at 1:45pm |
Can't you read & comprehend what I wrote!!!
Big Orange
Posted: 06 Oct 2018 at 2:49pm |
ALLIS DAVE The dirt and gunk settles to the bottom of the pan at the drain plug area, at oil change, with hot oil the dirt is drained out. That's how the non detergent oil works. Detergent oil keep dirt in suspension, so the dirt is pumped to the bearing, as there is no filter to stop it. GOT IT
Big Orange
Posted: 06 Oct 2018 at 3:02pm |
HoughMade
you hit the nail on head, detergent oils hold dirt in suspension, with no filter to stop the dirt it goes to the bearings & everything.
Big Orange
Posted: 06 Oct 2018 at 3:20pm |
Years a go, these old tractors were worked hard, sometimes 24 hours a day, pulling a plow or disk, with different drivers of-coarse, in very dirty conditions. Not like today, pulling a hay-rake or baler.
DougS
Posted: 06 Oct 2018 at 3:23pm |
Actually the dirt builds up on the parts and in the passages. It’s your tractor, so do what you want. Take an engine apart after using non detergent oil for 4000 miles and you’ll see that the dirt didn’t settle in the pan.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
So why even have a filter?
Big Orange
Posted: 06 Oct 2018 at 3:31pm |
These old engines really don't have a filter. A bypass filter, filters very little oil.
Big Orange
Posted: 06 Oct 2018 at 3:39pm |
In ten years time, these old tractors probably had 6 to 8,000 hours on them.
