WD45 Serial Numbers |
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Topic: WD45 Serial NumbersPosted: 10 Apr 2010 at 8:53pm |
according to tractor data it should be on the left brake housing...no dice....where else can I find the number to see what year mine is?? Only number I've found was 150217 on the back of the rearend housing but I havent found it to cross to a serial....any help would be great....thanks.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Posted: 10 Apr 2010 at 8:57pm |
That could be it if it has WD in front of it and it's hand stamped. It would be on the back side of the rearend just below the left brake inspection cover. 1953 if that's it.
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
That would make it a 1953
