WD45 Serial Numbers
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Serial Numbers
    Posted: 10 Apr 2010 at 8:52pm
according to tractor data it should be on the left brake housing...no dice....where else can I find the number to see what year mine is?? Only number I've found was 150217 on the back of the rearend housing but I havent found it to cross to a serial....any help would be great....thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 9:39pm
It's a 1953.
Model 1950 1951 1952 1953 1954 1955 1956 1957 1958 1959
U 19-30 ? 22823 20586-20748
22824-23056
B 114526 118673 122309 124201 124710 126496 127185 - - -
C 84030 - - - - - - - - -
WD 72327 105181 126981 131242 160384 - - - - -
WD45 - - ** 160385 190992 217991 230294 236958 - -
G 24005 25268 26496 28035 29035 29036+ - - - -
CA 321 10538 22180 31423 32906 37202 38617 38618+ - -
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 10:36pm
That will make it a 1953 if that is the serial number you found.
1953- 146607 to 160385.
The chart above shows last numbers for the year.
Edited by Jeff Z. NY - 10 Apr 2010 at 10:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 8:19am
hey thanks so much....had it out and worked it a bit for the first time....pulled a few stumps with it....did well though the clutch needs adjusted a bit, and clean because the rear main leaks....is that a big job to do? I have the seal and a new pan gasket.....just needs done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 11:35am
WD-45 production began at 146607 in 1953 and ended at 236958 in 1957.
The last WD's numbers could match some of the early WD-45 numbers
I believe:
The 1953 WD started with serial number 131243 and ended with serial number 160384.
The 1953 WD-45 started with serial number 146607 and ended with 160385 in 1953.
If the engine is original it will not have the steel plate on the right side of the engine if it is a WD-45.
Also the WD oil filter housing had one line coming out of it and the WD-45 had a tee in the bottom of the housing for two lines.
The serial numbers in  the chart posted are year ending numbers not starting numbers for the year and I think there are mistakes in that chart also.
Edited by Jeff Z. NY - 11 Apr 2010 at 11:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 12:49pm
I guess you could have a 53 WD45 or a 54 WD. I never noticed that before till Uncle Theo pointed it out to me. Thanks Ted.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 2:30pm
146607 was the first WD45, all the other charts disagree with that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 2:44pm
OK Norms books says 146606 was the last WD. Benny, only the earliest WD's had the number stamped on the right side of the left brake housing. All later WD's and 45's were stamped on the back of the differential housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 2:45pm
I guess both places could be considered the left brake housing, just one is on top and the other on the back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 7:28pm
that makes mine a 53 WD45...thanks so much for the help guys
This page was generated in 0.114 seconds.
