WD45 + rotary cutter
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 + rotary cutter
    Posted: 16 Aug 2020 at 1:57pm
Will a WD45 handle a Woods BB840X-P or a DS8.30?
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 5:11pm
Well, I don't see why not. Mine pulls a 6-footer and even on bad hills and tall, thick weeds the WD45 rarely grunts. Might need to use a lower gear, but I would say that's about as big a mower as I'd go.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 5:12pm
Meaning, the ones you mentioned would be about as big as I'd use.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 9:22pm
I would strongly suggest an over-running clutch.  A lot of momentum in those larger blades.  I have seen tractors pushed through fences and in some cases pto housings severely  damaged.
The 45 will have the power to handle it.
Good Luck!
Bill Long
