WD45 rebuild progress
 Post Reply Post Reply Page  <1234>
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 7:03am
I got the full Felpro oil pan gasket set last night. I includes the 2 long gaskets, the 2 short gaskets you stick in a can to curve, the main seals and the small F gaskets for a 45. $17 part# FPG OS30130C
I already had Felpro main gasket set part# FPG BS40010. It included the rear main seals, upper main carrier to block gasket, and the F gaskets. $12
I bought a new set of head studs, when I got looking at my old head bolts, someone mixed a set because 4 were grade 2's in there! They should be grade 5's or better. Like Don says make sure all the threads are good and the bolts don't have any pitting.
Brian,
All the wrist pin bolts face toward the cam side. cylinders 1,3 and 2,4 are the same I believe. Depending on which cylinder you're going in, you slide the pin to one side of the piston or the other and slide the rod over until it touches the piston on that side. Then the wrist pin can't get over far enough to gouge the sleeve. The crank/rod position pulls the pin opposite direction a little to center the pin. The service manual spells it all out with pictures. I wouldn't install the pins without staring at the book.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 7:34am
Like Dr Allis using tape I cut a thin (.002") piece of brass shim stock to just fit around the shaft then rap it around the shaft starting with it about 1/4" ahead of the front end shaft and ending it just short of where the seal starts to inter the front cover, I also pack the back inside of the seal with grease, that will help hold the spring in place and wipe some grease inside on the seal lip.
One thing I have found over the years is; most wrench's will have some little tip they use and have good luck with, so I say find the one's you like and take the time to rebuild it right and the build will last along time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 11:50am
Oil Pan Installation
First off, if you haven't watched DonMO's oil pan gasket video. Watch it! Even if you're not rebuilding and are just bored one night, watch it.
http://www.allischalmers.com/forum/forum_posts.asp?TID=93356&title=oil-pan-gasket-video
I won 't try to re-explain everything in the video, but here's the quick run down, of what I did.
Clean up the pan and block with my trusty die grinder and scotch bright pad. The pan was straight and the corners measured in spec so pretty simple preparation. I ran a tap through all the holes.
There was one spot on the pan between 2 bolt holes that I could feel a small dip, so later I put a little extra sealer in that spot.
After sitting for a couple months in a pear can, previously full of delicious pears, the main end gaskets held their share very well. I never knew the gasket clips existed before. They make holding the gaskets in place a breeze.
I made 4 alignedment studs by butting the head off of a few bolts which made installation much easier also. I laid out the gaskets on the block and made a few lines with a marker where I wanted the gaskets to sit. After removing the gaskets, I put a thin layer of #2 permatex on the block to stick the gaskets to. I laid the gaskets back in their place. Then I put another thin layer of permatex on top of the gasket to seal and pan imperfections. I put a little extra in that spot where the small dip was on the pan gasket area. I probably didn't need the extra sealer, but I know it won't leak.
I put a good dab of sealer in the 4 corners where the gaskets meet. If you don't put a little sealer in these corners, I don't see how the gaskets would ever seal well. You can see I didn't put globs on. Just enough to seal the corners and any surface imperfections. Hopefully NO LEAKS
It takes quite a bit of tightening to get the end gaskets drawn down good. I went around the pan about 4 times tightening a little at a time with a 1/4 ratchet, because I have a tendency to over tighten. I imagine you could twist the pan by initially tightening down in only a few places. I ending up with the torque wrench and tightened down to 10ft lbs. In Don's video he said 18lbs, but just 10lbs felt like a good amount on these little grade 2 5/16 bolts. Everything looked like it was squeezed down good, so I stopped there. The manual doesn't even give a torque spec and I imagine over-tightening is worse here than under-tightening here.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 12:14pm
Dave,looks like things are coming right along.keep the posts and pics coming.enjoy watching the progress.Thumbs Up
Post Options Post Options   Thanks (1) Thanks(1)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 7:59am
All of the previous posts were work already completed that I hadn't got time to post. Now I'm up to current where the motor sits now. Today I'll talk about some of my mistakes that I'd rather leave unsaid, but sometimes we learn more from what we do wrong than from what we do right. Hopefully some other green people like me can learn from my mistakes and not repeat them.
Lessons Learned
I've really been going about this rebuild the wrong way. I've been treating it as a bunch of "stages" as I've gotten time to work on it over the last few months instead of one large project.
For example, I waited to clean up and disassemble the oil pump until the day I was going to install. I found the broken spring and had to pay shipping and wait for just one spring. Had I checked all my parts before starting assembly, I could've had less part orders and a quicker assembly.
I'll say now that preparation is the key!
When Don says start with a clean block, START WITH A CLEAN BLOCK.
don't do like I have and wait to tap out the oil pan boles holes until you install the oil pan or the head holes when you install the head. This makes it a lot harder to keep the block clean when you are always introducing dirt. Also clean ALL of the gasket surfaces first. If you are worried they will rust, apply some oil after they are clean and clean off with a rag soaked in breakclean later. Don't introduce all that dirt into your block when parts are already in it. Same is true even if your block was hot tanked like mine was.
Now I'm just stalling...
Since I didn't prep well, I waited to clean up my head bolts until I was going to install the head. When cleaning, I quickly noticed that 3 or 4 of the head bolts were only grade 2! Maybe that's partly why I was having some head gaskets issues... I'd been on the fence about new head bolts before, but now I knew I should just remove the existing studs and buy ALL new matching studs/bolts.
I went and borrowed a stud remover and pulled the 3 3/8's studs. One came out pretty hard but didn't break. Moved on to the 2 1/2 studs where the thermostat sits. The first one turned HARD. I walked back with a pipe to put on the 1/2 ratchet, and hope I didn't break the stud, when I realized I was tightening the stud instead of loosening. I went the correct way and the stud came out, only to let me see that while I was tightening the stud, the stud remover was drawing down on my block and sleeve making a nice gouge in my nice new sleeve!
Had I cleaned and inspected the bolts BEFORE I wouldn't have had this problem even if I did tighten the stud.
Luckily FredPA was able to find me another one of these rare 4" sleeves. Everything will be made right, but all completely avoidable...
I will save the sleeve and maybe have a couple thousandths turned off of it and pack it away as a spare. I'm sure someone will need one someday.
When I have the oil pan off again, I'll also use this time to pull out the rod bolts again and tighten up any of the nut "locks" that are a little looser than I'd like and add a drop of red Loctite before tightening.
The last thing I would've done differently is to have the block decked and recut the counterbores to make a perfect block. I bought a straight edge and some spots I only have .001 standout when I get farther to the edge of the block. Generally I'm at .0015-.003. I'll probably be fine, but I'd feel better knowing it was perfect.
So I guess, don't cut corners, prep, and plan well!
Well the motor goes back into the bag for the night. The dog was excited, I let her in the shed for a couple minutes. She tends to cause more harm than help if she's in there too long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:25am
Dave looks like you have learned a lot along the way of your own engine rebuild. good job.
I'll bet you will rebuild the next one a lot faster. I have not posted all the little tips that help me, so here's a little tip I do on the head rebuilding, I strip all the guides, manifold studs and have the top, bottom and the manifold side of the head all trued, that helps stop coolant leaks around the thermostat housing and back two bolt cover to head, valve cover and manifold.
Keep your posts coming it's nice to see someone learn old tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 1:08pm
Experience is a great teacher....sometimes it teaches hard lessons.Worst part for me is by the time I do it again,I've forgotten some of the pit falls and learn the hard way ....AGAIN!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:55pm
Dave,
 Good documentation and lessons learned too! Beefy tires you have on the WD45! Its going to be a good strong running tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 8:12am
I didn't get(make) much time to work on this thing over the weekend. Still waiting for parts to be delivered too.
Head work
I put the head together about a month ago. I had the bottom and manifold side of the head milled. Manifold was also milled to true it up. All new valve train was installed, so new valves, guides, springs, and retainers. They weren't too bad, but I also had new hardened seats installed. The only thing I didn't think to do was to have the top of the head milled. I had no leaks there before so I should be fine, but it would've been a nice extra.
I spent about 10 minutes with the air nozzle blowing any junk out of the passages that I could break loose.
I got some valve grinding compound and lapped each valve into it's new home. As expected with new valves and seats, they lapped in perfect. I carefully cleaned up all the grinding compound and lubed the valve stems. I also cleaned up the spring seats good and oiled them up. I used my free spring compressor that an old tenant left behind to install the spring, spring seat, cap and retainer. This head had the valve rotating caps for the exhaust valves.
I did take the thermostat and front water jacket block cover to work and sanded them back flat on the granite block. They were pretty off!
Edited by Allis dave - 14 Sep 2016 at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 8:25am
Dave you might test fit the manifold to the head before installing the head, I have seen the carb shaft rub the side of block after head and manifold milling.I'd set the head on the block and set the manifold on with the carb bolted on and check it. It might be good to go I'm just saying check it. lol
Edited by Don(MO) - 15 Aug 2016 at 8:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 9:21am
Thanks Don, I'll make sure to test fit that.
Do you have any tips to get the manifold lined up? There's a lot of room to slide it around on those 3/8's studs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 12:13pm
If the old manifold is been milled to the point the carb is rubbing the block I have it re-milled about 95* angle not the normal 90* or let the top or the manifold lean to the right of the tractor a little, if you go to far with the milling the hood will hit the muffler.
Or just get a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 12:42pm
Sorry, I meant, when you install the manifold, there is a lot of room to shift the manifold, up & down, or left to right on the studs. Is there a way and is it beneficial to try to get the manifold centered so the ports transition correctly, or should I just put the nuts on and not worry about it. This is all IF there are no clearance issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 2:08pm
I just center the studs in the holes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 2:20pm
Thanks, that's how I've done it in the past, but I thought maybe there was a better way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:19pm
You are OK with a stock manifold and no porting of the head to do it like Steve said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 9:22am
My new ARP head studs came yesterday. The ARP studs are overkill compared to the original grade 5 head bolts, but I decided that it's worth it to me to have a high quality fastener that will torque down as a perfectly matched set. I think it's even more important with the higher compression that I'll be running.
I put them all in the block last night for a test fit. a few of them are too short so I'll have get a few different ones. Now I know the correct and incorrect way to measure for studs before buying... I'll post the correct sizes once I get everything correct. The 1/2 studs go a lot deeper into the head which should give some extra thread strength
They are beautiful studs.
I cut a strip of cardboard and laid it on the block over the cylinders for a layer of protection and set the head on for a test fit. I put in two manifold studs and put on the manifold and carburetor. The carburetor and choke rod didn't hit the block, so the head and manifold weren't milled too much.
When I set the rocker assembly on the head, I found that the stud nuts and washers are the little thicker than the bolt heads were so the end of the rockers assembly sat on top the nut and was help up about .100. If I use the nut with no washer It just barely clears. I should've taken a picture...
I think I'm going to pull the valves back out of the head and have the valve cover surface milled a little and have the machinist take a about .200 off the 2 separate head stud bosses under the ends of the rocker arms.
I looked and can't find the gaskets that go under the thermostat housing or front water jacket block cover so I'll be doing like Dr. Allis suggests and just putting some sealer there. Having the top surfaced should make sure I can make a good seal there.
Edited by Allis dave - 14 Sep 2016 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 10:12am
Dave, before you pull the valves and send it back to the shop I'd call them and ask if they can go around the guides. I have the top of 201/226 heads done with the guides out makes it a one time pass over the top, just saying call before you go to that work. You might be better off to reorder bolts under the rocker arms, you will need to use the washers on the head with ARP bolts or studs and nuts. I can see what your head bolt holes looks like without seeing it, the bolt holes are not nice they might even have pieces of the head gone around them that's why I said to use the washers.
You are going at it right so stay in-there you will have a nice engine when you are done with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 10:16am
I for got to say change the two head bolts at the end of the rocker arm shaft too.Studs,washers and nuts will hit the shaft too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 10:25am
you go dave!!!dave, just a thought,is it the outer diameter of the washers that's not clearing?if so, wouldn't be simpler to cut down the diameter of the washers to get your clearance?   never mind dons got ya covered.guess i type too slow,lol.
Edited by ac45dave - 17 Aug 2016 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 10:33am
If have the time and just looking for right as rain (as Dad used to say) set a manifold gasket on all the ports and center them to the port draw a line around them , use the lines to center the manifold to head. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 11:04am
It's the two studs/nuts at the end of the rocker shaft that don't clear.
Dave,
It's not the diameter of the washers that doesn't clear, it's that the thickness of the nut and washer together is thicker than the old bolt head. When I set on the rocker assembly, the shaft sits down on top of the nut. Lets say the rocker shaft sits .600 above the head, well the nut and washer are .700.
Don,
When I was trying to eyeball with a straight edge last night, it looks like the guides are a little below the valve cover surface. Are they usually above? When I was at the shop yesterday, he said he'd have to push the guides out if they were above the surface.
No wonder you've got so many tractors lined up for repair. You never get to work on them because you're too busy helping us. lol
Edited by Allis dave - 17 Aug 2016 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 6:37pm
Be sure to mark the flywheel for 25 degrees BTDC instead of the 30 degrees it is now, if you are using D-17 pistons/sleeves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 8:02am
Thanks Doc,
I was planning on setting timing to 23degrees. These are 175 pistons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:56am
Finally got the rest of the parts and head work done and now back to work. I'm not sure which takes longer, the actual work, or the posting.
Head Studs
The final head stud sizes I used are as follows:
4- 1/2 x 6.120
5- 1/2 x 5.750
3- 1/2 x 5.250
3- 3/8 x 5.150
The ARP studs seems to be very high quality fasteners. Beautiful studs with nice flanged nuts, and good washers.
I borrowed and re-ran a bottom tap through all the holes in the block to get a couple extra threads holding onto the studs. I had to cut a little off the 2 studs under the end of the rocker arm to clear. I also cut a little off the center stud under the rocker arm. I almost touched the rocker arm spring and I was worried maybe they touch and wear the spring through over time.
The 6.120 studs went under the thermostat and water jacket blocking cover. They were just barely long enough under the thermostat. I didn't use a gasket there. If I had, 6.120 wouldn't have been long enough. Next size longer was on backorder.
I lightly oiled the threads and official installed the studs finger tight into the block.
I took the head back to the machine shop and they took .010 off the top valve cover surface. That should make sure it's trued up good and the thermostat housing and front water jacket cover seal good.
Then he threw the head into the mill and touched up the center stud bosses to make sure they were perfect. Most importantly, he cut a little down into the two stud bosses under the end of the rocker arms to make room for the stud and nuts. Still not enough room for a nut and washer so I'll just use the nut. With a good flat surface and some special ARP lube it should be ok.
Edited by Allis dave - 14 Sep 2016 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 9:05am
Head Installation
I got the head put on last weekend too.
I was reading through some old posts about if I should put and type of sealer on the head gasket. Lots of opinions out there about the copper coat, hi-tack, aluminum paint, and Red RTV sealer.
I finally decided to put a light coat of High-Temp Red RTV sealer around all of the water jackets and oil ports. This block always seeped oil out the push rod side (before the head was milled) so I thought this might be a good way to keep everything where it's supposed to be.
Because the coolant passages in the head gasket on the push side are sized smaller than the block passages to regulate flow, I put the sealer on the block here instead of the on the gasket. Did the same on the head.
Here you can see my coating on the head gasket. I did the same to the bottom. The gasket will crush down pretty good so I only put a very light coating and smeared with my finger and wiped off the excess.
I take it as a good "sign" because it almost looks like Persion orange in the picture
I also didn't notice until I was looking at the picture that I didn't put any sealer around the blocked off coolant passages. It wasn't intentional, I just didn't think about them leaking since they blocked.
I set the head on the block and squeezed a bead of special coolant gasket sealer for water pumps and thermostat on the head around the water jackets for the thermostat housing and the jacket blocking cover.
I didn't use gaskets here because Doc said not to because he's seen them squeeze out under the head stud torque. My studs at the thermostat weren't long enough for an extra gasket layer anyway. When I flattened out the t-stat housing and block cover by sanding, I could see the blocking cover was humped in the center pretty good I assume from the ends of the gasket crushing more than the center. No, no gaskets seemed like a good idea. Both surfaces are flat so I shouldn't have any leaks. Doc said he doesn't.
A tube of ARP's special lube paste came with the studs so I lubed up both sides of the washers and the stud bosses where I don't have room for a washer. I lubed up the stud threads and the nut flare and put them on finger tight. That ARP lube is some slippery stuff!
Torque values
The WD45 Service manual says to torque 90lbs on the 1/2 studs and 25lbs on the 3/8 studs.
ARP says their studs are rated for 110lbs and 45 lbs. I Didn't want to go that much because I don't know if the block would handle it OR crush the gasket too much.
A D17 switched from 3/8 to 7/16 studs and torqued them to 70lbs. Since I have 175 pistons I figured a little extra torque would help and not crusht he gasket too much.
A very good mechanic that I know said 25 seems very low for a 3/8 stud. After a little research on other applications, it seems like most 3/8's are torqued between 30-40.
So... I finally decided to torque the 3/8 studs to 35lbs and 1/2 studs to 92lbs.
I torques the nuts in 3 steps following the stud order in the service manual. I used 30lbs, 60lbs, and 92lbs steps for the 1/2 studs, and 12lbs, 24lbs, 35lbs for the 3/8's.
To properly torque the nuts under the thermostat, I used this nifty wrench that Don helped me find.
http://www.allischalmers.com/forum/forum_posts.asp?TID=115588&KW=thanks+don&title=wd45-engine-rebuild
After the last torque step, I hit them all again, then I went back again after a couple days and retorqued to see if anything was stretching. A couple of the nuts moved a little, but not too much. After the motor heats up and cools a few times I check them all again cold.
Here's the head all installed and the motor ready to be painted.
Edited by Allis dave - 19 Sep 2016 at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 6:54am
Dave,
 Nice documentation on the 45 engine rebuild. I would like to build one some day. May need your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 10:18am
Dave I hope you changed the two cork plugs in the ends of the rocker arm shaft. They are a #2 cork plug, drive them in just flush to the end of shaft and drill hole to install the cotter key. If you push them in pass the cotter key hole it will cover the rocker arm oil hole.
Or cut about 1/8" off the little end of the cork and drive them in just pass the cotter key hole in the shaft.
Edited by Don(MO) - 18 Sep 2016 at 10:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 11:55am
Dave - I have not seen RTV red silicone used like that on a head gasket.   Where is that excess going to go when you torque the head down?  I would be afraid excess would squish out where you don't want it or it wouldn't have anywhere to go and you'd have a high spot were it wouldn't seal?  Not an expert at this by any means.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:32am
Don,
I wasn't going to replace the cork because it looked ok. It's at least 35 years old though so I probably should.
Mike,
I figured there wouldn't be anymore (probably less) squish than painting with aluminum paint, hi-tack or copper coat and would only put sealer where needed. I used a pretty thin layer too. I'm not an expert either so I guess I"ll find out how it worked sooner or later. Doc recommended the Red RTV once in an old post.
After reading the back of the RTV sealer tube it says not for use on head gaskets. So use at your own rick...
Edited by Allis dave - 08 Feb 2017 at 8:06am
