WD45 Radiator
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Radiator
    Posted: 07 May 2018 at 7:47pm
So I got a new clancy radiator for the 45.  Did a dry fit and as fully expected as nothing is ever easy, the fan blades do not clear the radiator...I do hope what is pictured below is about dialing in or out the fan blade to make it clear.  Of course that is frozen up too...
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 7:59pm
Adj at pulley only adjust the pulley .Not to sure but i think fan blade is on reversed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 8:05pm
That adjustment is for the width of the sheave only. Looks to me that your fan is on backwards. You might try flipping it around and see how it fits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 8:22pm
Hmm.....on backwards?  Would that push the air the wrong way?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 6:58am
My 45 has a 5 blade fan. It wouldn't clear my new radiator shroud. I had to grind a little on the blades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 7:57am
Not only when you reverse the blades, you turn it the other way so it still moves air, just not as efficiently. Look at the blades. They should look somewhat concaved away from the radiator. Sort of like this. l (
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 11:54am
I see,,,
Well if I meet my Dad in the next life, will ask him whaddup with dat!? But perhaps it came from the factory that way....afterall he did find ball bearings in the oil pan...also the old radiator had the corner braces torn...or bent out....thats an indicator things werent right..
Thanks for the info guys.
This page was generated in 0.127 seconds.
