WD45 Purchase for $1500. advise
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 9:26am
fixed one valve stem hole on my wd45...chipped out bad metal with welding hammer...formed a large fender washer in there from the inside with the 5/8 hole..tacked it on the inside and ground flat so it didn;t rub on tube...built up outside with wire welder and ground down...nobody ever knew till i told em
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 11:56am
Buy it, even if it turns out to be a piece of junk, which I doubt, you have a 3 point adapter, blade, wide front end, and loader that should be worth 3-400 each, plus the tires at least 500.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 1:41pm
Here is some info on the 3 point it has, its a Speeco.  My WD has one, but I'm missing the top link.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
