WD45 PTO ?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: WD45 PTO ?
    Posted: 22 Jun 2020 at 8:06pm
Does the oil in the hydraulic system also lube the PTO? Looks like it does. When changing oils in a non running 45 the hydraulic drained OK from a drain plug. When I remove the plug on the PTO it was black and was so thick it barely came out and did not resemble the hydraulic oil. Do I need to get in there and clean it up?
Thanks Larry Miller
I used to be young and stupid, now I am not young anymore.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 8:11pm
They're separate. The PTO gearbox, hand clutch compartment, trans, and rear end all share the same gear oil. Since the PTO gearbox is the lowest point that's where a lot of gunk ends up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 9:07pm
OK, I have to go look again & drain all & refresh. Thanks
This page was generated in 0.284 seconds.
