wd45 power steering reservoir gasket |
sling-it ![]() Bronze Level ![]() Joined: 01 Oct 2010 Location: Iowa Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Aug 2025 at 8:03am |
I've got a Char-Lynn power steering pump on my WD45, and the darn thing simply will not seal. Does anyone have a source for the rubber gasket for the lid? I tried cork, but it won't quit leaking until it gets about half empty. It's roughly 5 1/2 in diameter, and I just don't know where to look for it, and I've got a feeling cutting one myself is just another recipe for failure
Edited by sling-it - 04 Aug 2025 at 8:06am |
albatros_3 ![]() Silver Level ![]() Joined: 16 Apr 2012 Location: SE Michigan Points: 451 |
I had the same problem with the resevour on my system. I added some gasket maker to both sides of the cork gasket and that fixed that leak.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5147 |
Get a new rubber gasket from Stiener for a 600-800 Ford with the Eaton PS Pump it will be the same.
