Wd45 power steering leak |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1346 |
Topic: Wd45 power steering leakPosted: 31 Aug 2023 at 11:51am |
Hi a’ll!!
So I’m getting really tired of this power steering leak and can’t figure out how to fix it… I’ve replaced the O-ring but it helps for awhile than it leaks all over again…
Stan R
Posted: 31 Aug 2023 at 12:40pm |
I'd scrape all that paint off both surfaces, run a flat file on each side (unless both sides are "somewhat" flat), and use a touch of rtv silicone in the o-ring groove.
MACK
Posted: 31 Aug 2023 at 9:32pm |
The boring under cap is only a dust seal. There is orings on spool that need replaced. MACK
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 01 Sep 2023 at 6:38am |
Look at the barrel when you have the spool out. Water will form pits and the o-rings will not seal.
http://lonsallischalmers.com
ac-mike
Posted: 01 Sep 2023 at 7:39am |
I had the same problem. Mine would leak oil while it was not running. I did everything I could think of twice. Finally, I noticed the cap was slightly sprung or warped. I straightened it that stopped the leak. Good luck, this kind of problem can drive you nuts.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
55allis
Posted: 11 Sep 2023 at 10:34am |
Thanks Mack!!! I didn’t even know there was O-rings there…. I replaced the O-rings and it works like a good Allis should!!! |
55allis
Posted: 11 Sep 2023 at 10:37am |
It doesn’t have anything in there to catch my finger nail on and no rust in there (it surprised me) so I think it’s ready to roll!!!
