WD45 Plow hydraulic Spring
BCPuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Plow hydraulic Spring
    Posted: 07 May 2011 at 11:35am
I have a wd45 with a three bottom plow. we are trying to setup the hydraulics.
i am thinking there is a spring coming from the back of the hydraulic pump going up to the hand clutch cover? is this correct. there is a pin coming off the back of the pump where the linkage comes from the hitch. If there is a spring suppose to be there what size or how strong or does it matter?
thanks
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 12:36pm
Hope this helps ypu
Edited by John (C-IL) - 07 May 2011 at 12:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 12:42pm
John,
Yes it does thank YOU! i have 5 wd45 and not one has a spring on it. My neighbors have 4 wd45 and non of them have a spring. great Picture. I will hook up my spring!
do you have your frame rail removed?
thanks
agian!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 3:10pm
The spring doesen't have to be anything special.I have seen some very flimsy ones that still seem to work.Just has to keep a decent pull up on that lower pin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 3:30pm
Ok, good, that was my next question. thanks
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 3:31pm
hmmmm!!! guess i'm going to have to look, now!  What does it do, modulate the action of the valve?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:23pm
   You guys are talking about the spring right below the bungee strap hook in John's pic, correct ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:37pm
All the spring seems to do is keep the slack out of the linkage.  Without it the plow will porpoise in and out of the ground, and not maintain a consistent depth, if it will stay in the ground at all.  (The voice of experience)  LOL
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:40pm
  there is a hole in 1 corner of hand clutch cover for it hook into  [all i ever seen] my 2 cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:41pm
  sorry we also keep them in stock   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:16pm
rfdeere
yes that is the one we are talking about.
will try it out, I do that when the snap coupler spring moves the linkage rod moves and if the spring is on there it will raise the plow. not sure
This page was generated in 0.069 seconds.
