WD-45 Paint questions
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Paint questions
    Posted: 17 May 2010 at 11:55am
Been looking at paint, and no one really replied to my post on paints...the stuff at tractor supply seems ok....its not like Im making a show tractor....I want it to be respectable though....where can I find High Temp AC Orange for the engine?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 12:09pm
The restoration series at tractor supply seems to work OK, leans more to the PO #2 though than PO #1 but personally for a work tractor I don't mind at all.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 12:10pm
what is better reccomended for a better paint job? I dont have a ton of money to dump into paint which can happen pretty quick....someone said PPG and my pockets arent that deep right now lol
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 1:22pm
I used the Valspar Paint from Fleet farm lokked good. and went on easy. I'm not a good painter. after about 15 years sitting in the sun it faded back to the color it was befor paint. My Nephew used the paint from tractor supply when he painted his 4H project 5 or 6 years ago it still looks good.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:11pm
My kid did a cub with IH red from TSC. In one year, without a doubt, it looks like horse puckey. It this East Texas humidity it grew black mildew all over and is the same color now as the tires. Think its cheap paint? It is. My CA painted 2 years ago with cheap PPG OMNI under the same conditions looks like new.
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:16pm
I just started using delfleet essential which is a 3 part part It flows out beautiful and his alot more chip resistant.The restoration grade paint is not bad but it does chip easily
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:42pm
I'v had a suggestion of epoxy primer, claims its good to 1200 degrees and won't come off an engine.  I will be able to tell you more when I get the WC done.  I have the primer and PPG #60080, got both from Keystone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 4:55pm
I think a major question would be, will it sit outside or in?
Charlie
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 5:03pm
be sure to use the hardner regardless what paint you use i buy agco paints but i bought a gallon off of the yt website and it went on very nice now for the test of time David
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:06pm
90 percent of the time it'll be inside....its mostly for antique shows and pulling
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:10pm
  Hello Benny  You don't need hi temp paint, only the exhaust manifold gets hot enough to burn paint.   The statements made about cheap/expensive paint are true.  PO#1 was used from 1930-1960 pumpkin orange,  remember it's your tractor.
