WD-45 Oil Change
Brewhaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brewhaha Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Oil Change
    Posted: 05 Jul 2011 at 3:24pm
Good afternoon I have a question about where to pour the new oil into a WD-45, I see a cap on the valve cover that says oil on it do I remove the hood and pour it in there, or there is also a cap next to the distributor that looks like it may be for adding oil.
Thanks,
Aaron
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:44pm
either will work. Never had my hood off, so obviously have always used the one by the distridutor.
1950 WD, Duetz Allis 613
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 4:53am
yup just pour it in the cap by the dist.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 5:14am
Yep just use the cap by the distributer.
1955 WD-45 with factory PS
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 6:31am
While your at it, clean the breather cap on your valve cover with some gasoline or thinner and then oil the wire mesh again. Keeps dirt out of the engine. Same with the cap next to the distributor if that one is the breather style too. Don't forget the air cleaner oil.
Wink
I am a Russian Bot
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 5:41pm
Lonn has it right.....after all, it is called a "breather cap".
It is more often overlooked on the early A-Cs because its up under the hood.
But...it should be cleaned and reoiled regularly.
