WD45 No start mystery
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 No start mystery
    Posted: 07 Jul 2017 at 9:25pm
Long post, read carefully.
A few months ago I picked up a nice original WD45.  Bad wiring and a sticky starter did not make it start at the auction.  However, I pulled it 6', jumped the clutch and drove it home.  The engine ran beautifully.  I have not run it since this time.
Here is what I have done in the last 2 months:
Cleaned out fuel tank and sediment bowl
Rebuilt carb
Blew through fuel line and topped up tank with fresh fuel right from the gas station
Completely new wiring harness
New key switch
New ammeter
New light switch
New thicker battery cables
New battery (came with tractor)
Rebuilt starter
New spark plugs
New plug wires
New 12 volt coil with internal resistor
New distributor cap and rotor
New Pertronix 12 volt (Negative ground) electronic ignition
New engine oil and filter
Boiled out rad and new coolant
New Nelson muffler
Rebuilt generator, new voltage regulator, new fan belt
With all of this new stuff, you would think it would start right up (other tractors usually do).  For the life of me, I cannot get it to fire.  It cranks over great, but it backfires and spits flame out the air tube of the carburetor.
I am getting tons of spark at the plugs thanks to the EI and the carb is getting lots of gas.  I even put the carb on from my 54 WD45 (which I know is set properly and works great) - no change.  Putting my hand over the air tube of the carb while cranking gave lots of suction, indicating no blockage in the intake.
Thinking it was a valve issue, I popped off the valve cover and checked out the pushrods and valves for proper movement.  Nothing stuck and the head looks real clean inside.
I have hit the wall.  I cannot think of anything else to check or what could be the problem.
Any ideas on where to go from here?
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:45pm
My guess...out of time...like 90 or 180 degrees?  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:52pm
Sounds like you gotta couple plug wires crossed or maybe all 4 off 1 hole on the dist cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 11:13pm
Timing was not disturbed.  Spark plug wires were ran exactly like the ones on my 1954 WD45.  Helps to have the same tractor which runs!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 11:19pm
OUT OF TIME.       MACK
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 11:20pm
I would have to agree your timing is off maybe you mixed up the wires.
I would set number one to TDC and check timing marks it also wouldn't hurt to do a compression test.
firing order is 1243
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 4:48am
Timing is off. The wires may not be positioned exactly the same  as your other WD 45. Find TDC on number one and go from there.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 6:37am
If you did not change the rotation of the distributor.
Just rotate the spark plug wires over on the cap till you find it runs.
As other have stated it just depend how the person set the distributor before you # 1 is different on the cap from the one you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 6:51am
 If you didn't replace the plug wires one at a time, but pulled the whole works and put them back in order by looking at another tractor, you have no way of knowing they are in the right position.
 Take the #1 plug out and hand crank it till you feel compression on that cylinder. Bring it to the top of the stroke and look where the rotor is pointing. THAT is where the wire for #! has to go. Follow clockwise around the distributor by firing order for the rest of the plugs.
Edited by CTuckerNWIL - 08 Jul 2017 at 6:53am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 7:18am
You said you changed distributor cap and plug wires, so there is where it could have got out of time.    MACK
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 9:31am
I have done a couple of these pertronix installs in cars recently. Had to reset timing in both cases. Maybe that is all thats wrong here. Once timing was set they worked well and no issues so far. Lately I see some problems on our site here tho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 8:24pm
Many thanks to all you guys.  The spark plugs wires were in the wrong order.  I will get the distributor reset this week, but it sure is nice to have it running after a lengthy rest.
Here is a little video (hope it works)
https://youtu.be/rQpoMqrft5A
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:17pm
Sounds GREAT Myron!!  Amazing what one little ole hole will do to them. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:41pm
Don't feel bad I had 2 and 3 mixed up on my 47 c for months couldn't figure out why I had no power felt dumb after.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 9:08pm
Motor sounds great.  Always feels so good to get them purring!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 6:35am
Hey, we're all human. Happens to the best of us including myself. Been a mechanic for 50 years, still sometimes screw up a firing order once in a while or do something dumb! Sometimes ya stand there saying "I don't believe I did that"! But you did!!  LOL!  Now that its running nice, its time for a paint job! I know what you'll be doin' this Winter!  Keep us posted Myron! You guys do some beautiful work man!  Thumbs Up
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 10:23pm
Steve@B&B
Sorry Steve, no fresh paint on this bird.  Keeping it's original patina.  I'll probably try waxing or buffing the 60 year old paint out a bit.  Still trying to get my 190XT together and out of the shop.  This WD45 didn't help that effort!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 6:55am
Could be worse..... I spent 2 hours changing points, condensor, coil, etc.....
Just to finally figure out that the wiring was bad just enough that it would show good Voltage on a Digital Multimeter, but not decent enough to carry the current needed to fire the thing..... I was embarrased that the guy helping me pointed out that there was no spark when he stuck a screwdriver across the points and stated the obvious....
DUH!  I cut the wire off the switch, hung it on the battery and the thing ran!
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 11:10am
I see from the video that the distributor is turned 180 degrees from where it usually would be timed.  Makes no difference in how the tractor runs, but if you change it around, you'll have a little slack in #4 spark plug wire anyway!!  LOL
