WD45 Ignition Switch
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Ignition Switch
    Posted: 14 Nov 2011 at 11:28am
My WD45 currently has a toggle switch for the ignition and I was wanting to put a key switch back on it. I bought one of those universal key ignition switches from tractor supply. It is to bulky and won't fit with the fused light switch I have in the way. Anybody know of some smaller switches that will work?
I have a inline fuse on the power wire going to the switches. The light switch is fused and I have it wired for one pull headlights come on....second pull headlights and back light comes on.
Can I just use a regular light switch instead that doesn't have its own fuse? That would make the switch less bulky. The new ignition switch I bought might fit then.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 11:55am
As long as you have a fuse in the circuit some where you will be fine.
1969 190XT series 3
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 5:31pm
I stock a  nice  2  wire  ing switch.  Have  one  on my  45.  www.tonystractors.com        look in electric dept.      Tony
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 5:37pm
THe ones for a Ford (8N 800) are simple on/off switches. TSC has them
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 6:45pm
    WE HAVE 2 DIIFFERENT SWITCHES THAT CAN BE USED ON A WD45
    1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 6:57pm
I would try to figure out a different ignition switch.  I would like to put the type of light switch you have on my tractor! One pull the headlights, two pulls and you get front and rear lights!!  Can't find a switch like that around here.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 7:04pm
I have a 8N ignition switch in our WD and the key position is oppisite of the correct switch. What was off is now on and on is now. Buy the correct switch is my suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 7:14pm
Evidently, you aren't running a 6 volt generator with a cut-out relay. That is what the 3 position switch with the fuse was for. First position had the field windings wired through a resistor, second position was for lights with the field grounded for a full charge, third position was just the field grounded for a full charge.
 If you no longer run the cut out, you can remove the big switch and replace it with something smaller without a fuse, as long as the lights are fused somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 8:18pm
We have lot's of Ignition switches in stock. Can probably fix ya up with one that will work nicely for ya. Drop us a line......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 8:55pm
I'm not running the stock switch It was discarded years ago....I am using a switch from the farm store for the lights and it has a built in fuse. I have a inline fuse in the wire providing power to the switch also. I'm gonna do away with the fused switch and get a regular one and see if that gives room for this ignition switch I bought.
Edited by 79fordblake - 14 Nov 2011 at 8:59pm
