WD45 ignition coil
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Topic: WD45 ignition coil
    Posted: 16 Aug 2023 at 11:01am
Spreading manure Monday with one of my 45's and it started missing. Sounded like on of those green things when I got home! After lunch I went to swap it out with my other 45, but no start. Power all the way to distributer with key on. Put in a premium tuneup kit from Steiner (made in Taiwan package said). No help. Swapping coil for a spare. Now here is the question- coil on the tractor (which had been running for years) had distributor post wired to ignition wire, and battery post wired to distributor .?.? This would seem to be backward to me..do I hook it up like the old one that worked or hook it up properly?? Or doesn't it matter ??   Thank you guys..(considered scrap gas, drained tank, sediment bowl, and carb bowl then put in fresh gas - no help).Dan
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2023 at 11:38am
If electrical system is positive ground that is  right. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2023 at 11:48am
If your BATTERY is Negative HOT -- then you connect to the NEGATIVE terminal on the coil.. If you BATTERY is Positive HOT ( neg ground)-- then you connect to the POSITIVE terminal on the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2023 at 1:04pm
Thank you guys..let me give that a go !!
This page was generated in 0.273 seconds.
