Wd45 hydraulics |
Page <12 |
hunter321
Posted: 03 Jul 2022 at 9:49pm |
I'm going to get a o ring to see if that's what's causing the leak
CTuckerNWIL
Posted: 04 Jul 2022 at 8:14am |
If you replaced the piston seals, and didn't remove the piston from the rod to replace the oring, it could be leaking by the rod threw the hole in the piston. That may have been the problem to begin with?
hunter321
Posted: 04 Jul 2022 at 7:26pm |
With the new o ring the cylinder no longer leaks.
But now it won't extend or retract once I put it back together |
hunter321
Posted: 04 Jul 2022 at 8:02pm |
I know it needs hydraulic oil but it won't move at all
Posted: 04 Jul 2022 at 8:05pm |
You need a gallon or more of hydraulic oil !!!
hunter321
Posted: 04 Jul 2022 at 8:08pm |
It has at least 1 gallon. When I first tested for leaks it raised in slow bursts then just stopped
Joined: 11 Sep 2009 Location: illinois Points: 90921 |
Posted: 04 Jul 2022 at 8:27pm |
it raised in slow bursts then just stopped......... Edited by steve(ill) - 04 Jul 2022 at 8:27pm |
hunter321
Posted: 04 Jul 2022 at 8:32pm |
Ok I thought I broke something or there was air in the cylinder.
How can I compress the cylinder so I can put it on the tractor |
Posted: 04 Jul 2022 at 8:35pm |
you can use a come along from end to end... or set one end of the cylinder against the wall or tree, and push on the other end with tractor, etc... take the hose off.
or you can pump oil or air into the VENT hole and push the piston back to the bottom.
Edited by steve(ill) - 04 Jul 2022 at 8:38pm |
hunter321
Posted: 04 Jul 2022 at 8:56pm |
How would I pump air into the cylinder
Page <12 |
