Wd45 hydraulics
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 9:49pm
I'm going to get a o ring to see if that's what's causing the leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:14am
If you replaced the piston seals, and didn't remove the piston from the rod to replace the oring, it could be leaking by the rod threw the hole in the piston. That may have been the problem to begin with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 7:26pm
With the new o ring the cylinder no longer leaks.
But now it won't extend or retract once I put it back together
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:02pm
I know it needs hydraulic oil but it won't move at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:05pm
You need a gallon or more of hydraulic oil !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:08pm
It has at least 1 gallon. When I first tested for leaks it raised in slow bursts then just stopped
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:27pm
it raised in slow bursts then just stopped.........
that normally means its out of oil..
Edited by steve(ill) - 04 Jul 2022 at 8:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:32pm
Ok I thought I broke something or there was air in the cylinder.
How can I compress the cylinder so I can put it on the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:35pm
you can use a come along from end to end... or set one end of the cylinder against the wall or tree, and push on the other end with tractor, etc... take the hose off.
or you can pump oil or air into the VENT hole and push the piston back to the bottom.
Edited by steve(ill) - 04 Jul 2022 at 8:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:56pm
How would I pump air into the cylinder
