wd45 hydraulics
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Topic: wd45 hydraulics
    Posted: 02 Sep 2010 at 11:31am
I have read on here before that most guys use Hy tran in the hydraulics of the 45...i was using 20w non detergent but napa is out and it's really hard to find...had to draibn mine again cause it got milky again and i found the drain on the bottom of the pump now which had a little water in it so i am looking for something more readily available and easier to get....preferably something napa sells since they are only 2 miles away...guy at napa tried to give me napa H O(?) hydraulic oil said it may be a hair thinner than 20w but not much..well i have a little leakage so i don;t want to go much thinner if i can help it
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 11:44am
No TSC nearby?  I buy their 5 gallon buckets of hyd fluid.  Works fine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 12:21pm
there is but it's further...napa is a few buildings from work....tsc is way the other way...will basically any universal hyd fluid for farm tractors work?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 3:37pm
Yes.
http://www.rumelyallis.com
