WD45 hydraulic pump
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hydraulic pump
    Posted: 27 Jan 2011 at 9:47am
Does any body have any ideas on what would cause the pump to be stuck in a constant lift.  When I bought the tractor it had a two spool hydrauic valve with one valve running the lift arms and one for remotes.  I want to undo this and hook the lift arms up to the pump the factory way and install a high volume belt drive pump that will utilize the spool valves for remotes.  The problem is that the factory pump causes the lift arms to rise no matter what position the controls are in and will not let them back down.
Thanks in advance for any help or opinions,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:05am
Have you checked to see if the traction booster linkage came loose?
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:48am
No I haven't I was going to compare it with another tractor but never got around to it I know it was rigged to provide constant flow so I don't know if it is just stuck that way or if it is out of adjustment or other problems,
Thanks,
Denis
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 11:24am
Either the traction booster linkage is waayy out of adjustment, or most likley the unloadeing valve is stuck in the pumping positon.    There is  thumbscrew on the front of the hyd pump behind the frame rail,  screw that screw all the way into the pump, that will force the unloading valve to the unloaded postion.  Do that a few times then unscrew it until the head of the thumbscrew is against the torque tube casting.  Most times this works, if it happens again real soon, or still keep pumping, then the pump will have to come off and  cleaned up.   Sometimes the check ball springs break up, migrate to the unloading valve and cause it to stick.   Good luck
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 12:34pm
I would check the linkages, Sounds like the previous owner rigged it up so it is pumping all the time and then they controlled by the hydraulics with the valves. Now that you removed the valves it is still pumping all the time.
below the gas tank, check where the control lever meets the pump.
Edited by Matt MN - 27 Jan 2011 at 12:34pm
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 2:25pm
Skip,your mixing terms.The control valves get the pieces stuck in them and the control valves are what the thumb screw pushes on.The unloader is in the other bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 4:14pm
Youre right Steve,   the control valves stick and cause the unloder not to unload??  or the control valves stick and the -   aw shucks-  you know what I mean Steve!!!!!!!!
This page was generated in 0.162 seconds.
