WD45 hydraulic hose needed?
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hydraulic hose needed?
    Posted: 29 Nov 2020 at 6:02pm
What pressure hydraulic hose will I need for the WD45?  Mine are blistering at the connections.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 6:26pm
  The WD45 hydraulic system produces over 3000 lbs pound of pressure. So get a hose rated for 4000 lbs of pressure.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:06pm
Go right to Agco! Just replaced both of mine. Fair price, perfect fit. Will cost you about the same to go to local hose shop.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 8:17pm
Need to be 4 brad hose.         MACK
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 8:21pm
1/4"x2 wire braid will work  for your lift cylinders.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
