WD45 Grill Ass. question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Grill Ass. question
    Posted: 18 Dec 2010 at 6:35am
I was going to pull the grill assembly and hammer out a few dents, but thin I notice it looks like you have to unbolt the radiator???
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 7:12am
Yup, there are 2 bolts holding it on.  Trick I learned was using a 3/8" x6" long extention and a 3/4" socket.  There is a hole in the frame unde the bolt head.  Put the extention through, then put the socket on.  Not hard at all.  Then you just need to make sure the angled washers go back on right.
AaronSEIA
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 7:44am
Not that hard unless the bolts are rusted in place. Can be hard to remove then.
Wink
I am a Russian Bot
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 11:53am
Are you asking about after it's off tractor? 2 bolts down on the side hold the shell to the radiator.Make sure cap is off and you pull bottom out first and fish neck out last.It can be a pain or go well,just depends.Almost not enough room to slide in or out but fits once it's there.Another learning curve,you can do it!
   There are 4 bolts(2 per side ) holding shell to frame.The 1/2 bolts holding rad frame go through rail flanges that are milled flat but the back two(3/8) use a wedge piece to "equal" out the flange angle.
Edited by Steve M C/IL - 18 Dec 2010 at 11:58am
This page was generated in 0.035 seconds.
