WD45 Grill Ass. question |
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Topic: WD45 Grill Ass. questionPosted: 18 Dec 2010 at 6:35am |
I was going to pull the grill assembly and hammer out a few dents, but thin I notice it looks like you have to unbolt the radiator???
German Shepherd dad
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2578 |
Posted: 18 Dec 2010 at 7:12am |
Yup, there are 2 bolts holding it on. Trick I learned was using a 3/8" x6" long extention and a 3/4" socket. There is a hole in the frame unde the bolt head. Put the extention through, then put the socket on. Not hard at all. Then you just need to make sure the angled washers go back on right.
AaronSEIA
Lonn
Posted: 18 Dec 2010 at 7:44am |
Not that hard unless the bolts are rusted in place. Can be hard to remove then.
Wink I am a Russian Bot |
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 18 Dec 2010 at 11:53am |
Are you asking about after it's off tractor? 2 bolts down on the side hold the shell to the radiator.Make sure cap is off and you pull bottom out first and fish neck out last.It can be a pain or go well,just depends.Almost not enough room to slide in or out but fits once it's there.Another learning curve,you can do it!
There are 4 bolts(2 per side ) holding shell to frame.The 1/2 bolts holding rad frame go through rail flanges that are milled flat but the back two(3/8) use a wedge piece to "equal" out the flange angle. Edited by Steve M C/IL - 18 Dec 2010 at 11:58am |
