WD45 governor question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 governor question
    Posted: 08 Mar 2011 at 6:37pm
Pulled the governor today to replace the gasket. Is it necessary to reset the ignition timing when I put it back on? Is there any easy way of doing this?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:37pm
I hate to rush an answer but I'd like to get it put back on tonight yet if I do not need to set the timing.
Luke.
German Shepherd dad
#WD234847
#WD88193
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:37pm
yes
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:47pm
If you mark the pointer and don't turn the motor it should be timed the same. Would be good to check the timing after you get to running.  MACK
This page was generated in 0.344 seconds.
