WD45 Governor Assembly
SmithCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmithCreek Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Governor Assembly
    Posted: 18 Aug 2010 at 11:40am
Where could I find a governor assembly (with or without distributor) for a WD45 like the one pictured below?  The threaded portion (for the rear distributor bolt) split off mine the other night when I was tightnening back up after adjusting timing...
Thanks
Edited by SmithCreek - 18 Aug 2010 at 11:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmithCreek Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 12:09pm
Goose...
This is not a picture of my tractor, I posted it to show the part I'm looking for.  Sorry for the confusion.
Also the bolt didn't shear off, instead the treaded portion of the cast iron housing itself broke off leaving me with the bolt and a piece of the housing in my hand...not good.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 1:48pm
Originally posted by SmithCreek SmithCreek wrote:
Goose...
You sire, are the very sort of person JB Weld was invented for.
If the piece in the photo truly is like yours - the part that attaches to the engine/timing case is held on by three bolts and it  is aluminum. The inside one gets overlooked by a lot of people - until just too late.
Anyways,  well scrubbed surfaces, JB Weld and a fresh gasket - and 20-30 years from now, it will still be holding.
Slipping on a fresh gasket between repaired joint & engine means it won't stick when you disassemble at some later time.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 6:36am
I would have the coplete governor assembly for $275.00.Would have the body (part you broke) for $80.00. 785-353-2392 Thanks
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 7:05am
i have one for 200$ complete
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 11:40am
One bolt/clamp is enough...been there.
