WD45 Gas
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Gas
    Posted: 13 Nov 2018 at 6:36pm
what is the wiring diagram for 12 volt generator   with voltage regulator. Is it the same as the WD45 Diesel?  replacing a bad alternator . All ready have the 12  volt generator.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 6:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2018 at 8:52am
Make sure we understand what your doing? Taking off a bad alternator and replacing with a good generator and a voltage regulator, correct?
Well then the factory wiring diagram should be what you need to refer to. If it had a alternator it was probably changed in the wiring system to a custom wiring system for the alternator which does not need a voltage regulator. That said, I would re-check and double check every wire in the system to make sure you get it wired correctly back to factory specs.
My tow cents I would put on a new alternator. But maybe your going for a original factory restoration project.
I know I did not help you much. I just got a service manual form Sandy Lake yesterday, but have not open it up yet.
Good luck with your wiring. My guess is that a WD45 Diesel may have a slightly different wiring system????? I am not sure. Gearld or Steve fro NJ will be along to help.
We need some pictures too! Please.
This page was generated in 0.111 seconds.
