WD45 FWA |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Topic: WD45 FWAPosted: 30 Oct 2016 at 10:00pm |
This isn't mine, but I wish it was! I think it looks really cool!
plummerscarin
Posted: 30 Oct 2016 at 10:30pm |
Ooohh I like that. I bet that would look good under Dad's 6 cylinder gas engine swap!
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 30 Oct 2016 at 10:50pm |
Now that is a kit you could sell. I would love one for my d15 loader.
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 358 |
Posted: 30 Oct 2016 at 11:01pm |
How is the front axle driven?
Are there any D17's like this? That is really great looking.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34432 |
Posted: 30 Oct 2016 at 11:25pm |
Can you imagine what a 170 or a 180 would look like with that set up on it...WOW!!!
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 30 Oct 2016 at 11:38pm |
Wow am180 or 190 Fwa would be awesome
AJ
Posted: 30 Oct 2016 at 11:51pm |
If I remember right that a John Deere front end that was modified to fit the front of that.
Can't fix stupid
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 31 Oct 2016 at 6:37am |
You could drive through almost anything with that!
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8627 |
Posted: 31 Oct 2016 at 6:47am |
Wow! That would turn a 45 into a real work horse!
Regards, Chris |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 31 Oct 2016 at 6:51am |
It appears to be driven by the PTO.
Gotta wonder if it has enough power to actually do anything though? Just guessing here but, gotta think it takes 10-15 HP just to run the front axle. A good running WD45 puts out 45HP. Take away 1/3 of that, and there ain't much left for pulling implement. All in all, it is neat looking though. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Allis dave
Posted: 31 Oct 2016 at 6:59am |
That's why it'd be perfect for the 6 cyl swap. You get some extra power and I bet since it'd be spread through the PTO and rear end you wouldn't hurt anything.
Dan73
Posted: 31 Oct 2016 at 7:54am |
I always wondered if you could find an ac elenco kit. I know that they where made for more then the fords. I have seen some on IH. But never on an AC. I can tell you the Ford 800 serries with one of those kits make a great improvement for a loader or plow tractor.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2434 |
Posted: 31 Oct 2016 at 8:49am |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 31 Oct 2016 at 8:52am |
If you take into account 15 horse for the front axle, you'd be right back to what a WD had for horsepower......
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Randy WI
Joined: 22 Jan 2014 Location: Ogema, WI Points: 846 |
Posted: 31 Oct 2016 at 9:11am |
Don't think that PTO drop gear box will hold up . I had one with that gear box was blown out running 9 foot haybine in heavy clover had to replace the torque tube. Randy
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 31 Oct 2016 at 9:24am |
Horse power is up with a G-226 like used in the D17/E Gleaner and the WC trans in front of the WD45 trans with front axle power is coming from the box coming off the back of the WC trans not the PTO box.
This is a 10 on the cool scale. |
Allis dave
Posted: 31 Oct 2016 at 10:13am |
I'd like to see it in person and see just exactly how they got all that linked together. I'd have to put a set of duals on it of course.
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 31 Oct 2016 at 10:29am |
you have a hard time getting those 45hp to the ground anyway. that was a big gripe of farmers back then the extra hp doesnt help if the tires just slip. now this is a good way to utilize the power
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12327 |
Posted: 31 Oct 2016 at 10:47am |
My very first thought was similar to that above, with the parasitic horsepower it wouldn't help that much. But then, I think of my MFWD tractor. It isn't all that high of horsepower, I think about 70. But that's irrelevant. My experience, if you are driving in a field, relatively loose or whatever, when you turn the FWA on, the engine actually picks up, in other words, runs easier.
Now that's compared to it pushing the "big" tires through versus them pulling, where the original wheels the 45 had wouldn't be such a draw. So, IDK. But, no matter, pushing any tires takes some HP, so it's not a comparison from 0. Anyway, looks good and cool project. |
Dan73
Posted: 31 Oct 2016 at 6:12pm |
Pushing the stock tires in mud takes alot of power if they are plowing. Proved that to a friend with a farmall M and a loader. He kept saying it was short on power cleaning his barn finial got him to put flotation tires on the front and he couldn't believe it was the same tractor. So it all depends. But plowing or using a loader i bet it actually uses the power better.
