WD45 Front Crank Seal Speedi Sleeve
Lingle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Front Crank Seal Speedi Sleeve
    Posted: 17 hours 23 minutes ago at 9:30am
during my rebuild, I must have overlooked the front crankshaft seal surface is deeply grooved.  I am looking for a speedi sleeve for it, still need to measure it to be sure, but thought I would post here if anyone knows a part number off hand.  I believe the front seal is a rope type, like the 2 piece rear main, but havent confirmed what is in my Reliance gasket kit, maybe its a rubber seal, regardless the seal surface will not seal given the deep groove in it.  thanks everyone!
35 and 41 WM crawlers, 49 WD, 53 WD45 wide front, 49 JD A, 52 JD B
