WD45 Fan Belt |
| Author | ||
Mark (ECIN)
Joined: 13 Mar 2024 Location: Hagerstown, Ind Points: 25 |
Topic: WD45 Fan BeltPosted: 13 Mar 2025 at 4:41pm |
I need to change the fan belt on a WD45. If I take the one bolt out that holds the bracket for the crankshaft (the one you crank the engine to start)....will it give me enough room to get the belt over the bottom pulley?
| Sponsored Links | ||
acd17toy
Posted: 13 Mar 2025 at 6:38pm |
The only thing you need to do to change the fan belt is remove the lower radiator hose.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 15 Mar 2025 at 12:16am |
Buy a new piece of hose and cut the old on off. You'll be glad you did.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4144 |
Posted: 15 Mar 2025 at 8:35am |
wjohn
Posted: 15 Mar 2025 at 11:22am |
x3! And unless you know the coolant has been changed, it probably hasn't been done for 50 years so might as well do that too.
Edited by wjohn - 15 Mar 2025 at 11:23am |
