Wd45 factory power steering leak
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 factory power steering leak
    Posted: 03 Jul 2025 at 12:15am
I have gotten very tired of the leak and now I want to get it fixed…
So first I should ask, is there supposed to be hydraulic oil in the plug (circled in red) on the top side of the steering valve?
Right on that cap (circled in blue) beside the plug is where it seems to be leaking all the time, really bad when it’s running and only a drip when parked and cool.
I know there’s a gasket on the cap that is bad but not for sure if that should make a difference.
It will drain the reservoir in 3 to 4 days without running it.
Thanks,
Gavin
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 6:28am
Replace the two o-rings. Item 7
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 9:05am
Just did and it’s still leaking out of the top cap…
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 9:39am
Observe rust pitts on item 8. That's why orings leak
