WD45 Exhaust gaskets/ keepers |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Feb 2022 at 1:03pm |
Yup Thanks. Dana
Blue Skies and Tail Winds
Dana |
pirlbeck ![]() Silver Level ![]() Joined: 01 Dec 2009 Location: West Central IA Points: 229 |
The problem is not the gaskets being wrong, the problem is the way the manifold is cast. Listen to Mack....... If spreading the gaskets will not work, grind the sides of the manifold down until the gaskets will fit.
I thought spreading them out will leave areas with no metal to hold the gaskets in place and will eventually erode out the gaskets and leak exhaust? I was hoping where to buy correct fitting ‘square end’ metal gaskets. Yes CHINA is stamped on the back side.
Dana |
Spread them out and put them on or do dome grinding on manifold. Probably a after market manifold. MACK
Help! So I bought all new exhaust gaskets for my WD-45 manifold and the outer two that are shaped uniquely square on the top and bottom are not wide enough the metal part is not wide enough to fit over the manifold I need ones that are one and a quarter inch wide at the top and the bottom of the square part. Can anyone help me? 🤔😂. As always Thank Y’all. Dana
Dana |
