Wd45 engine ?
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 engine ?
    Posted: 29 Apr 2019 at 2:32pm
? For Dr Allis ; have you ever used Hercules 2” journal rods 8 “ long on a 45 crank offset ground ? If so what piston did you use ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:25am
Never been there or dun that. Good luck.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 9:06am
Maybe Marty Nelson (Wi50)?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 10:30am
Marty liked to to use H farmall rods up to 5.5 stroke or so, never heard him say anything about hercules
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 10:11pm
I used a set in one engine. They're a nice rod. Just a bit uncommon to find is all. The engine I used them in was a deal where someone's crankshaft shop had messed up the crank so the I decided of the crankpins was off. I had to re weld it to get it ground correct. As far as piston, that's up in the air as to hour bore size, desired compression ratio, etc.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 10:18pm
I've got a bunch of flathead continental rods that are a 2.062" crankpin diameter and a few different lengths. 7.875, 7.937, if my memory serves me correctly. I don't have time to mess with much anymore but I've got a few sets of a few different lengths on a shelf that I'd like to get rid of if they interested someone.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 11:17pm
Marty, we may have to talk again. Been trying to build the WD up some more for the last couple winters but never seems to happen, hoping to try for this winter, if you have any parts laying around and a little guidance. Hope things are going well with the super.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 11:20pm
Interested in the longer continental rods how much do you want for them .
This page was generated in 0.234 seconds.
